RUTX11 reboots when using data
I have RUTX11 in my RV and I have continously problems with rebooting. It will reboot, when using data, for example when trying to make speedtest. What could be reason for that?
Probably power supply is to weak, not enough power for device and modem.
Check last power consumption table in: RUTX11 Power Consumption - Teltonika Networks Wiki
Hello @Reissa,
Could you please confirm if you have checked the power supply? Also, let me know if the issue still occurs when using the correct power supply.
Hi, thank you for the respond. The voltage of the power supply is about 13 V and it will provide 200 A current (2xlifepo batteries parallel). It is possible that the power cable is too small. I try to replace it but it will take few months to get results.
