The digital output pin of the RUTX11 does not react properly when enabling it. When output is turned “off” the multi-meter consistently shows 0.025 V. When turned “on”, it shows 0.056 V. There is a consistent reaction triggering on and off, but it is tiny and does not reach the expected 24 V when on. According to the documentation it shall reach 8-30 VDC (assuming the Vin, in this case 24 VDC).
Setup:
- RUTX11 with firmware RUTX_R_00.07.06.5
- 24V DC powering the RUTX11
- 4 Pin power cable giving access to digital input and output (PR2FK20M)
- Measuring with multi-meter
- Digital input works fine and registers on/off (24V/0V)
This behaviour is the same for 3 RUTX11, whereas 1 of them is an EU version and 2 of them are US versions.
Suggestion:
Can there be that an internal pull-up has not been activated for the output pin in the firmware?
Output Off:
Output On:
