RUTX11 no connect toharbor wifi
I see you are still running two SSID’s on 2.4GHz - we only want the ‘jachthaven’ SSID running on that frequency. You can enable the 5Ghz SSID for devices to connect to your router.
Does the marina run a captive portal?
At NETWORK > WIRELESS > SSID > jachthaven > GENERAL SETUP > NETWORK … should be set to ‘wifi1’
At NETWORK > WAN > wifi1 > PHYSICAL SETTINGS … I believe that ‘Bridge interfaces’ should be ‘off’, and ‘Interface’ should read ‘-- No interface --’
That’s about all I can suggest other than you could try ‘Multi AP’ mode, see below … rarely, after you have turned on the Multi AP SSID and the WiFi1 WAN interface, the router needs a reboot for them to take.
Multi AP mode is great for when you have to hook up to many different SSID’s when you travel around, as you can enter the credentials, and they’ll always be in the router.
