Device details:
Model: RUTX11
Hardware revision: 1010
RutOS version: RUTX_R_00.07.19.4
Modem: EG06-E
Current modem FW: EG06ELAR04A20M4G
Problem description:
The WebUI shows “Internal modem – Update available”.
However, the modem firmware update fails.
CLI attempt using dfota:
Preparing for gsm.modem0 update!
Searching for updates…
Update found! Update size: 17485208
Preparing system for update!
Found cmd port: /dev/ttyUSB2
Starting download!
Command failed: Connection failed
Firmware update verify was unsuccessful… ErrorCode: 174
Reseting modems due to error!
Update script done!
CLI attempt using rut_fota:
Connected to rut.teltonika.lt:5000
Connected with SSL
SSL read returned 0, error 6
Failed to retrieve command from server
Communication has failed
DNS and TCP connectivity to rut.teltonika.lt:5000 are confirmed working.
Please provide:
The correct EG06-E modem firmware image for this specific device (manual DFOTA upgrade),
or -
Confirmation whether this device / HW revision is eligible for the currently advertised modem update.
Thanks in advance!
