Hello, i want to implement a solution for my system without Modbus MQTT Gateway… Only because my system isn’t made to work with receiving requets and responses…
What i want is to make a system that reads from the modbus requests (already setup) and send and receive data to and from the mqtt broker.
I managed to do it with “Data to Server”, but i want to read also some data and write via Modbus running on my PLC…
Is it possible to do? I’ve been looking at a solution through scripts and LUA.
The main point at hand is that you need a way to publish the requests, but since your system doesn’t support such functionality, I have my doubts that even with the use of custom scripts, it’ll be hard to achieve such a configuration. Writing these custom scripts is out of our scope, unfortunately, so I’m unable to provide you with any examples, even if such a script were possible to create. Using a Modbus MQTT gateway would be the ideal solution here, since that’s its main purpose.
The main takeaway from this would probably be switching the system in use, using a different solution perhaps, which would be compatible with MQTT gateways and such.
Well, maybe i didn´t explain myself correctly… I want to read from MQTT and send to my PLC via Modbus. (When you say publish, you mean send from the MQTT Broker to the RUT?)
I’m already publishing using the Modbus Client and Data to Server… But now i want the backwards implementation, i want to read messages and make the connection to a modbus request.
Also i found a response on another topic from your colleague Daumantas, saying “this can be done using scripts…”
Apologies, but could you please provide the exact thread that you were referring to?
Either way, if a custom script is required to achieve this configuration, you’ll have to look into it. If you do figure out a way, it would be amazing if you could also share the solution with the community in case someone else with a similar question/issue comes around.
this will make it possible to install the pub sub client.
After that, using WinSCP i transfered to my RUT a library called ModPoll that allows me to make modbus requests to the PLC running a server, and get returns of data.
After that i implemented this code (shell script):
# MQTT Broker IP address
BROKER="broker_ip_address"
# MQTT Broker port
PORT="1883"
# MQTT topic to subscribe to
TOPIC="testmosquitto"
PUB_TOPIC="testmosquitto/data"
# PLC IP address (Modbus TCP slave)
PLC_IP="plc_ip_address"
# Modbus slave ID on the PLC
SLAVE_ID=1 (or 16#FF = 255)
echo "Starting MQTT listener..."
# Subscribe to the MQTT topic, pipe each received message to the while loop
mosquitto_sub -h "$BROKER" -p "$PORT" -t "$TOPIC" | while read -r payload
do
# echo "$(date) Received: $payload" >> /tmp/mqtt_log.txt # Uncomment to enable logging
if echo "$payload" | grep -q "on"; then
echo "Command: READ 5 holding registers starting at 40001 (addr 0), poll once"
# modpoll -m tcp -a $SLAVE_ID -r 1 -c 5 -t 4 -1 $PLC_IP
# Run modpoll once, capture output
result=$(modpoll -m tcp -a $SLAVE_ID -r 1 -c 5 -t 4 -1 $PLC_IP 2>&1)
# pub the full data
echo "Publishing Modbus data to topic $PUB_TOPIC"
mosquitto_pub -h "$BROKER" -p "$PORT" -t "$PUB_TOPIC" -m "$result"
elif echo "$payload" | grep -q "off"; then
echo "Command: WRITE value 1 to register 40001 (addr 0)"
modpoll -m tcp -a $SLAVE_ID -r 1 -t 4 $PLC_IP 255
else
echo "Unknown payload: $payload"
fi
done
And this is the outcome:
Basically i publish the word “on” and that will generate a modbus request to the server running on my PLC, and return the data to the script that will publish to my broker the information (i didn’t format the message yet…)
