The LAN port mirroring settings seem to have disappeared in the webui. I was trying to use Wireshark to troubleshoot but not possible.
Has port mirroring been removed or did I fail to find the setting?
Thank you for your inquiry and for sharing your observations regarding the port mirroring settings.
We are currently analyzing and working on your request. Once the investigation is complete, I will get back to you with an update on the port mirroring functionality.
Thank you for your patience and for bringing this to our attention.
Thank you for your patience.
According to our R&D team, WebUI support for port mirroring will be restored in the upcoming 7.18 firmware release. In the meantime, you can still use this feature via the API (documentation available here) or by editing the configuration directly.
Feel free to reach out if you have any further questions or need assistance.
OK,
and thanks for the workaround.
