RUTX11 Internal modem is unreachable
Cellular not working due to Internal modem is unreachable
Model - RUTX11
Firmware - RUTX_R_00.07.16.1
 Teltonika RUTX series 2025
Device: RUTX11
Kernel: 6.6.92
Firmware: RUTX_R_00.07.16.1
Build: a01c4c02aa1
Build date: 2025-07-16 05:11:04
root@RUTX11:~# opkg list | grep -e modem_updater
modem_updater - 7.16
root@RUTX11:~# opkg update modem_updater
Downloading https://opkg.teltonika-networks.com/6ccee39b39f0a3875f185805acc8576dbca8b3bb1a95243f5a996e292fb4796b/Packages.gz
Updated list of available packages in /var/opkg-lists/tlt_packages
Downloading https://opkg.teltonika-networks.com/6ccee39b39f0a3875f185805acc8576dbca8b3bb1a95243f5a996e292fb4796b/Packages.sig
Signature check passed.
root@RUTX11:~# opkg install modem_updater
Package modem_updater (7.16) installed in root is up to date.
root@RUTX11:~# modem_updater -g
Command failed: Not found
Modem List:
root@RUTX11:~# ll /dev/ttyUSB*
crw-rw---- 1 root dialout 188, 0 Jul 22 14:32 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 Jul 22 14:32 /dev/ttyUSB1
crw-rw---- 1 root dialout 188, 2 Jul 22 14:32 /dev/ttyUSB2
crw-rw---- 1 root dialout 188, 3 Jul 22 14:32 /dev/ttyUSB3
root@RUTX11:~# lsusb
Bus 003 Device 001: ID 1d6b:0002
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 002: ID 04b4:6572
Bus 002 Device 001: ID 1d6b:0003
Bus 001 Device 003: ID 0a12:0001
root@RUTX11:~#
Unfortunately, based on the lsusb output, it appears that the modem is no longer recoverable programmatically.
You will need to contact your distributor to initiate the RMA process for device repair.
