RUTX11 has internet but not connecting to RMS
We have an Nvidia device with a camera plugged into a RUTX11 (this is on a seperate subnet from the rest of the network), the RUTX11 is then connected via wifi as a client to a router plugged into a starlink. The NVidia device (which does not have wifi) is showing online via a direct stream of the video from the camera which we can see remotely, however the RUTX11 is not showing as online on RMS since midnight. As we use RMS for SSH this is an issue, thanks.
Hi MartinAce,
Welcome back to Teltonika Networks Community!
May I confirm if you have sufficient credits assigned to RUTX11 so it can be managed through RMS?
You can verify this by click the device → Manage Services. It should show you when the credit will expire.
