RUTX11 GPS NMEA forwarding
Was using the GPS NMEA forwarding on a RUTX11 as a data stream backup for GPS software on boat.
The RUTX11 ip is 192.168.2.1, connects by ethernet to a router on boat, the LAN is 192.168.0.1 and device is 192.168.0.30.
I had set host on RUTX11 as IP of the device running software.
Host 192.168.0.30
UDP
Port 60000
On device on LAN, the connection was set to 192.168.0.30, udp, port 60000
This worked up until updated to RUTX_R_00.07.14
Now I get no data received at the device
Is there another way to configure this or a better way?
I tried reverting to the default port 8500 and cannot receive NMEA data on the LAN any more since latest firmware.
I set the host as the WAN IP of the LAN Router, and port forwarded to the laptop - started working (UDP only)
