RUTX11 fw RUTX_R_00.07.05 no longer support ubus call sim change
Since flash to RUTX_R_00.07.05 , this command no longer works - " ubus call sim change " or “ubus call sim get” command.
I there some other command can run in a script via ssh to initiate a sim change? or is there a possibility to have a button or quick way o select sim in use?
Indeed, the commads you have mentioned are no longer valid in the newer firmware version. Now, you can use the following commands:
# get current SIM slot
ubus call gsm.modem0 get_sim_slot
# swap to other SIM slot
ubus call gsm.modem0 change_sim_slot
# change to specific SIM slot
ubus call gsm.modem0 set_sim_slot '{"index":1}'
Apologies for any inconvenience this may have caused.
Thank you for that, resolved issue.
