RUTX11 forward broadcast UDP to VPN
Hi guys,
I have a RUTX11 connected to a OpenVPN server through a connector.
The RUTX11 has two devices connected to the LAN (here called DEV1, DEV2)
On the OpenVPN server I have another laptop (here called PC1) connected as a simple device (no connector).
The whole network and routes are setup properly, so from PC1 I can ping DEV1 or DEV2, and viceversa from DEV1 or DEV2 I can ping PC1. In my setup DEV1 is sending UDP broadcast messages that I can clearly see from DEV2. But these messages cannot reach PC1.
I am aware that any router is usually discarding any broadcast message, so this is why I tried to setup a port forwarding to PC1…but no success.
I have tried to use the UDP broadcast relay package, but it relays messages only to the interfaces (LAN or WAN).
Any idea how the broadcast can reach PC1?
thanks in advance
KR
Davide
