Hello everybody, since the last modem-firmware upgrade (july) i can’t send SMS any longer. An update to the new version fails. I got the info, that it is possible to flash the firmware after uploading it into the local file system. I paste my SSH output:
root@rutx11:~# cat /etc/version
RUTX_R_00.07.16.6
root@rutx11:~# gsmctl -y
EG06ELAR04A20M4G
root@rutx11:~# dfota -u
Preparing for gsm.modem0 update!
Searching for updates...
Update found! Update size: 17485208
Preparing system for update!
Found cmd port: /dev/ttyUSB2
Starting download!
Command failed: Connection failed
Firmware update verify was unsuccessful... ErrorCode: 174
Reseting modems due to error!
Update script done!
root@rutx11:~# ls -l /dev/ttyUSB2
crw-rw---- 1 root dialout 188, 2 Dec 2 21:15 /dev/ttyUSB2
root@rutx11:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: seq=0 ttl=113 time=34.216 ms
64 bytes from 8.8.8.8: seq=1 ttl=113 time=41.900 ms
^C
--- 8.8.8.8 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 34.216/38.058/41.900 ms
root@rutx11:~# nslookup google.com
Server: 127.0.0.1
Address: 127.0.0.1#53
Address 1: 142.250.180.206
Address 2: 2a00:1450:400d:806::200e
root@rutx11:~#
Any help would be appreciated! Regards from Vienna.
