RUTX11 Default password
Is there a way to access the default password of the RUTX11 login through the terminal? I’d like to be able to access that info on RUTX11’s that I do not have easy physical access to. Firmware version is RUTX_R_00.07.03.3
Default password (as such) is always changed on first power up unless of course you have manually reset to the default. Without physical access then use RMS?
Aaand keep your box up-to-date and safe by upgrading the firmware.
You’re quite far behind with 07.03.3
RUTX11 Firmware Downloads - Teltonika Networks Wiki
Accessing the device via terminal requires a password. Therefore, it would be counterproductive to obtain the password this way. The password is a crucial security measure and access without it is not possible for your own protection.
