I apologize for any inconvenience; I misunderstood your previous message and have now noticed that there is already a topic created regarding this issue. I will test it and get back to you.
I sent the form. ![]()
Thank you! You should receive an email from us shortly.
How can I replicate the issue? The mobile data usage happens continuously. I understand the reason for your request, i.e. to see what happens in the logs if a certain situation is triggered. But in my case, I donât have a trigger - mob1s1a1 is used instead of WiFi. Can you please provide me with some additional guidance how to proceed? Thank you so much!
You should receive all the instructions via email. Please reply to our email if you have any further questions or concerns.
I have replied and look forward to hearing back from you. ![]()
@Marija In the past 2 days I have sent several emails to community-networks@teltonika.lt with notes and some attachments about this issue (as instructed)
I just want to make sure they were received?
(reference to 9204)
@luckman212
@Marija
Wasn"'t the ticket ID 9204 for me? Not that our accounts are mixed up.
Iâm still waiting for an answer to my email before I send my troubleshoot file.
@7wells I am not sure if 9204 is only for you or is for both of us.I received an email from Marija on 2024-10-01 12:58AM (GMT-5) asking me to submit details and it said to use 9204 as the reference, which I did. I havenât gotten any reply as of yet.
Hi @Marija
Iâm still waiting for a reply to my email. Have you received it?
Still there is no feedback on my question that I sent by email. My questions were:
Hello @luckman212 ,
You should receive an email from us shortly. Thank you for your patience!
Hello @7wells ,
I have checked, and the email was sent to you on October 2nd. I have resended it; please let me know if you receive it or not. Thank you!
Hello Marija!
Yes, I received an email but was (and still am) hesitant to send out a troubleshooting file that contains personal information. Therefore, I had asked if I could do something about it. This question has not yet been answered, except that I should not worry. Well, I do.
By the way, do you receive emails sent to:
I sent a message to you via this email address, and I do not want to repeat it here. It would be good to know, if you received it. Thank you.
Best regards
7wells
I have the same problem with data on mobile even though primary was never down. I believe the problem is the way IPv6 is used in this case, I donât think this was fixed: Failover (mwan3) + dual stack IPv4/v6 on only LTE interface - #3 by Daumantas
If I donât need IPv6 (I donât know if I need it or not) and disabling IPv6 would help, I would disable it. But how? And would it really help?
Furthermore, I would like to see more guidance regarding the proper use of the 4 different options for âFlush connections on âŚâ:
These can be set (any combination or none) for any of the WAN interfaces used for failover.
In my case, I only use primarily (at home) RUTX11-WiFi to WiFi in the house and secondary (when abroad) the RUTX11âs mob1s1a1 (SIM1) interface.
So how should the aforementioned options be set for
interfaces for a proper failover function?
Any further guidance is highly appreciated.
Maybe I will provide Teltonika with my troubleshooting file, but first I would like to redact my personal info contained therein.
I wonder why a redaction cannot be done automatically, e.g. by pseudonymising personal data. Home Assistantâs ESPHome addon has such a feature (âstreamer_modeâ):
Hello @7wells ,
Unfortunately, we havenât received your emails. Please make sure that when sending emails, you reply to our previously sent email. If you compose a new email instead of replying, we may not receive it.
Regarding the troubleshoot file, it includes sensitive information. Unfortunately, there is no way to download a troubleshoot file without this information.
This happened to me again after last weekâs RMS outage. The device recovered, but I believe that the RMS connection remained established via LTE. This caused many hundreds of MB of data to be consumed per day, leading to my data cap getting breached prematurely.
Do I need to set up a cron job that resets rms_mqtt every hour or something? I donât know what to do here but this is not sustainable!
related: RMS service locked to LTE / WWAN / mob1s1a1 connection
