For others wondering why the distfeeds aren’t working on the RUTX11 FW 7.06.6, it seems like the configuration file is just in the wrong place.
Broken:
root@RUTX11-F25C:~# opkg update
Downloading http://opkg.teltonika-networks.com/676de56fa350c8a1ae7d062c2848851713bbc30853e05ec1ca288ae9a6175079/Packages.gz
Updated list of available packages in /var/opkg-lists/tlt_packages
Downloading http://opkg.teltonika-networks.com/676de56fa350c8a1ae7d062c2848851713bbc30853e05ec1ca288ae9a6175079/Packages.sig
Signature check passed.
Fix:
root@RUTX11-F25C:~# cp /etc/opkg/openwrt/distfeeds.conf /etc/opkg
after that, the sources can update:
Downloading https://downloads.openwrt.org/releases/21.02.0/targets/ipq40xx/generic/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_core
Downloading https://downloads.openwrt.org/releases/21.02.0/targets/ipq40xx/generic/packages/Packages.sig
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/base/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_base
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/base/Packages.sig
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_luci
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/luci/Packages.sig
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_packages
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/packages/Packages.sig
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_routing
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/routing/Packages.sig
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_telephony
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/telephony/Packages.sig
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/vuci/Packages.gz
*** Failed to download the package list from https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/vuci/Packages.gz
Collected errors:
* opkg_download: Failed to download https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/vuci/Packages.gz, wget returned 8.
Which allowed me to install nmap:
root@RUTX11-F25C:~# opkg install nmap
Installing nmap (7.80-3) to root...
Downloading https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/packages/nmap_7.80-3_arm_cortex-a7_neon-vfpv4.ipk
Configuring nmap.
