Is there any DHCP server existing in your end device (i,e, Wifi)? You can enable Force option under Network → DHCP → Advanced Settings. I have a RUTX11 here running on the same FW and DHCP is working as expected.
OK, this immediately fixed the LAN problem, but only partially resolved
the Guest Wifi . I at least got an IP address but no default gateway was
assigned nor was a DNS server.
I added these additional options to the forced menu for the guest network
advanced config (image for those with the same issue trying to replicate my actions:)
Actually the issue is still unclear as I have created a guest network. But under LAN section, it is showing Status: up. Once I connect to that guest network, my phone was able to get an IP within 192.168.20.1/24 subnet.
I have yet to wipe the box and try it on a fresh config
as it is the only present servicable spare.
However, the guest network is radiating and I get both DHCP success and internet access
with clients
But as per the previous picture, the GUI reports the guest network as DOWN when it is up , and wired when it is wireless
[NEXT DAY EDIT] I also notice that your guest network is configured as a bridge , I assume to LAN ? This I wanted to avoid. Guest traffic has WAN access but to no other zone [/EDIT]
