RUTX10: using WAN port for a VLAN
Hi All!
I’m trying to configure a WAN port on RUTX10 to be part of a VLAN, I’ve done this with RUT2xx and RUT9xx devices with no issues, but on this RUTX10 (latest firmware) I can’t get connected through the WAN port, but the LAN ports works just fine.
I’ve seen some tutorials to combine the WAN with the LAN, but that connects the interfaces, I just want VLAN 500 to be untagged on the WAN port, just like the other ports that work fine…
What am I doing wrong? or is there a bug in de RUTX series?
Thanks for reaching out!
We have step by step instructions on our Wiki page about that. You can access that page from here. Please go through it and let me know if you have any further questions!
Caner
Hello Caner,
That works if I keep the WAN port on vlan 2, but now I’m connecting interface eth1 with eth0.500 I would prefer to just use eth0.500 on the WAN interface.
Is vlan 2 (or eth1) hardcoded on the WAN port or something?
Dennis.
This should the naming of the VLANID. And yes, VLAN2 is hardcoded for WAN port by default.
But you can change the configuration from the Network > VLANID section of the WebUI.
And from the Network > LAN section of the WebUI you can change the physical settings of the LAN. Lets say you can assign ports to your desired LAN’s.
You can reach the detailed information from here and here.
Please let me know if there is anything else I can help you with!
Caner
I’m Sorry if I’m not very clear, English is not my native language.
This is what I was trying to do, but it seems that no matter what VLAN ID I put on the WAN port it will only work with VLAN 2.
I mean the physical “WAN” port, not the WAN-interface, it’s called _wan5 in the “network” config file, I even tried to call it _lan5 but then the GUI for the speed selection breaks :slight_smile:
Also tried to make it’s role ‘lan’, doesn’t work.
I think it’s a bug, I’ve configured other RUTs like this and I didn’t get this issue. I’ve configured a RUT956 and a RUT240 before.
Now I’m using a RUTX10 with firmware RUTX_R_00.07.08.3
VLANID1 and VLANID2 is reserved, to not to let incorrect configuration make devices inaccessible.It’s not bug its for security.
However you can create another VLANID’s, name as you wish, and you can connect the port the your desired VLANID’s, you just can not delete the VLANID1 and VLANID2.
If you made any changes, I recommend to factory resetting your device before proceeding further!
Please let me know if this helps.
Caner
I’m aware that VLAN ID 1 and 2 can’t be removed, but I was trying to set VLAN 600 to LAN 1 and LAN 2, and VLAN 500 to LAN 3 and WAN.
Like this:
But on the WAN port this does not work, it does work on the LAN ports.
Now I’ve used your first suggestion and that works.
With on the interface a link to eth1:
This way the interface bridges VLAN 500 and VLAN 2 together, a bit dirty work around if you ask me.
I’m glad the issue is resolved and thanks for sharing your feedbacks!
I will send this ticket to our RnD team so they can see your feedbacks also!
Thanks and Kind Regards,
Caner
very interesting however, on the rut 11 with 00.07.08.3 the option to “use wan as LAN” is apparently missing?:
Fault ? consequence of upgrade with legacy settings ? or a feature please ?
Regards
BB
Can you please swith your configuration to “Basic Mode”
Caner
HI Caner, in basic mode it is there , but not in advanced ?
Is this a “feature” or a “Product enhancement opportunity” please ?
regards
BB
Thanks for your feedback!
I will inform our RnD team regarding your feedback!
Is there any further help needed on this topic?
Caner
