I do not understand which setting this is related to but very often the 5GHz network switches off completely and no device can initiate connection to it…
Thank you for reaching out.
The 5 GHz WiFi network should not switch off unexpectedly unless you turn it off manually. While it’s rare for the 5 GHz SSID to disappear or go offline, in most cases, a reboot should resolve the issue.
If the problem persists, try factory resetting the device and ensure the Transmit Power of the 5 GHz radio is set to 100%. Also, double-check that the antennas are screwed in properly.
Additionally, if your router’s firmware is outdated, I recommend updating to the latest version (RUTX_R_00.07.10), which can be downloaded here.
Feel free to reach out if you have any further questions.
