Hello, Is possible some how monitoring the RSSI of connection WIFI in RUTX10?. I have tried with MQTT but the value signal is N/A, and with SNMP not have value with RSSI.
Thanks.
Thanks.
Monitoring via SNMP, MQTT, or any other protocol doesn’t provide RSSI value for Wireless because it doesn’t have this value available.
Wireless has a signal strength that is calculated between AP and client device, which previously mentioned protocols can’t monitor.
