Please clarify what you mean when you say “Sometimes has trouble starting up” - what happens exactly?
The errors seem to be flash-memory related. Specifically, the router is having trouble reading the root filesystem (rootfs) from flash.
Could you tell me whether changing settings, for example, the name of your Wi-Fi SSID and then rebooting the router saves the changes? If it doesn’t - your flash memory is corrupted and you may need to either:
If option number 1 doesn’t work → Contact your reseller/supplier/distributor with the serial number of your device and ask them for an RMA, as this is hardware-related.
I did the reset of the device through bootloader. I could made modifications after the fresh install. I could still notice the errors in the log.
But, once I shutdown the device and power it up again, it will not start (WiFi Led off, no ethernet activity) for many minutes (I stopped at 5 minutes). After 3 retrial, it started after 75 seconds and worked normally.
I also tested with another PSU with same results.
We have tens of those devices, but it’s the first that has some failures.
Thank you for informing us & clarifying in regards to the overheating.
Unfortunately, but if the warranty isn’t valid anymore for this device in particular, then there is nothing that us, or the distributor can do, as we provide 2 years of warranty. After this period, if a case such as this happens, we do recommend looking into replacing the device with a new one.
We, ourselves, do not take money for repairs, unless the warranty isn’t valid anymore - we no longer take the devices in, unless it is for utilization.
While we don’t recommend doing so, if you know what you’re doing then you are free to try of course, though we will not be providing any details on the process.
