RUTX10 client mode Relay and relayd
Hi all
I’m trying to use RUTX10 in client mode to move between APs in a mesh network.
I was following the setup example but got a bit confused between 2 options available:
Relay which appears in lan interface configuration which lets me relay messages to a given IP, and Relayd which appears under Wifi configuration which lets me relay messages between the wifi interface and the lan interface.
What’s the difference between the two, and which one should I use if I want to bridge the wifi and lan interfaces?
To put it simply - Relayd should be used for bridging networks with upstream wireless interface (the WiFi network that the RUTX10 connects to), while relay is used for relaying wired interface DHCP messages.
Here are configuration examples for both functionalities:
Hope this helps!
