Hello, I have a RUTX09 router. I would like to provide an SMS notification about a power outage and power return. Is it possible to set this in this router? Thank you for any suggestion.
Thank you for your answer.
RUTX09 has an input/output option. By default, there are no pins 3 and 4 in the plug. I would like to know if after connecting pins 3 and 4, I will be able to set notifications of power failure and return?
As I mentioned earlier, there isn’t a feature to send notifications when a device experiences a power failure or shuts down. Only when it powers up can detection occur and notifications be sent.
While the RUTX09 does have I/O functionality, simply connecting pins 3 and 4 won’t achieve the desired result.
For more details about I/O on the RUTX09, you can visit: RUTX09 Input/Output Documentation
Hi.
Thank you for your answer. But I don’t think we understood each other. It’s obvious that the router will not send information about a power outage because it will be without power itself ![]()
I have a UPS power supply and control.
After converting the plug to 4 pins and configuring the I/O, I receive an SMS notification about power loss and return.
What I noticed were errors in the I/O software. does not save settings as it should. You need to refresh the page. I have the latest available software.
Thank you.
Regards.
