RUTX09 - RutOS 7.12 Events reporting via e-mail SSH event not triggering e-mail
Hi, just noticed with the RutOS 7.12 firmware that the SSH event reporting via e-mail is not working.
WebUI login and config change events are triggering the e-mail reporting, sending e-mails succesfully but SSH configuration doesn’t.
In the Events reporting configuration for SSL events, the “send test e-mail” works fine, e-mail is received.
When testing via SSL login on the RutX09 nothing happens, no e-mails are send.
Any ideas?
To clarify, as I understand, you are referring to SSH configuration change event reporting. The email report is triggered when there is a change in the /etc/config/dropbear configuration file or when modifications are made through the WebUI under System → Administration → Access Control → SSH settings – not when simply logging in via SSH.
If you want to receive email reports for SSH authentication events, then the Event Type in the Event Reporting configuration should be set to SSH.
I hope this helps. Let me know if you have any further questions.
Hi Martynas,
Thanks, I was referring to the SSH authentication events.
I thought this event was also triggered when logging in via SSH with RSA key authentication.
Using “root” login with password does trigger the SSH authentication event and e-mail is send and received.
