I have such a problem, I have a RUTX09 router with a configured L2TP VPN, the connection works, I can ping the router address of the LAN card, but I cannot ping any device connected via the network connector, I bet there is some bug in the traffic rules, does anyone have any ideas? I am attaching a screenshot of the settings. Regards
To enable communication between the client and server on the RUTX09 device, you can achieve this by adding a static route. Follow these steps:
Navigate to Webui → Network → Routing → Static routes.
For the server:
Add the following details:
- Interface: L2TP
- Target: Client LAN IP
- IPv4 Gateway: Client L2TP VPN IP
For the client:
- Interface: L2TP
- Target: Server LAN IP
- IPv4 Gateway: Server L2TP VPN IP
By configuring these routes, both the client and server LAN networks will be able to ping each other successfully.
Thank you for your answer, according to the drawing I want to have access to all computers marked in the drawing as PC1, PC2, PC3, PCx and each subsequent one connected to the switch via a VPN tunnel from my computer, today I can ping the local LAN address of the RTX09 Router but I cannot get to the computers marked in the drawing. Any idea what to do with the traffic on the router? Regards
