RUTX09 Internal modem is unreachable
I have issues on 2 RUTX09 which i upgraded the firmware to 07.20.1.
After the upgrade the internal modem was totally out with the message “Internal modem is unreachable (shut down unexpectedly)” displayed in the notification slide.
With the CLI i tried to obtain more information :
-”modem_updater -g”
-”lsusb”
-”ll /dev/ttyUSB*”
-”gsmctl -m”
So if i am correct, the internal EG06E Quectel modem is out or bricked on both RUTX09 but still seen on the usb bus.
If it is possible I would like to obtain some quectel firmware to flash it directly from the CLI via usb.
As the modem is unreachable for now i am enable to know the current firmware version, except if someone knows the path of the running firmware.
Thank you in advance !
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 17335.
