RUTX09 - EG060K Modem
Hi guys,
Could you tell me the batch number, that the EG060K modem was introduced for the RUTX09?
Many thanks
Mike
Agree, it would be beneficial if not only a change date but also a batch number would be mentioned in the documentation…
Cheers mate, hopefully the crew can tell me the batch number to make life easier with a visual inspection.
Hello @Mike,
Could you please clarify the reason you require information about the batch number in which the EG060K modem was introduced?
Thank you.
It’s all about maintaining an accurate Asset Register and our Configuration Management process. If device components require firmware, then we record it.
Thx,
Mike
The RUTX09 models began to include EG060K modems starting from approximately batch 66 (November 2024).
Additionally, there is a specific product code for the RUTX09 models equipped with EG060K modems: RUTX0920B200.
I hope this helps!
Thank you … Mike
You’re welcome!
Is there anything else I can assist you with?
