Hi All,
We are trying to integrate the SNMP OIDs and Traps to our BMS application via SNMP service. we have the router online in the snmp service but when we try reading the SNMP we are getting below error.
Firmware: RUTX_R_00.07.04.5
Hi All,
It appears that you are using an older firmware version. I recommend upgrading your RUTX08 to the latest firmware version, RUTX_R_00.07.06.10, which can be downloaded from here. After the upgrade, please check if the issue persists.
