Moving forward, RutOS API will be used to interact with the device, thus we suggest moving from ubus to the API for gathering information and changing the settings of the device.
API documentation can be found here: https://developers.teltonika-networks.com/
However, it should be noted, that API is still in beta, thus some minor issues can still be expected. Endpoints should not change throughout the v1 release, and they will be supported even when v2 comes out.
For OpenVPN in particular, API call to /openvpn/status can be used and it will return all information visible in the WebUI, including:
OpenVPN status
Transmitted and received data
Logs
Remote IP address and more.
If the calls are done via the router itself, you can skip the authentication step and use the api command:
root@RUTX09:~# api --help
This script allows calling api endpoint locally without using HTTP
Usage: /sbin/api <http_method> <request_path> [<request_body>...]
Example: /sbin/api PUT /interfaces/config '{"data":[{"id":"lan","netmask":"255.255.255.0"}]}'
The ifconfig command can be used, however, if you are planning to unify the scripts to use the new API, then the status could be obtained using the following command:
/sbin/api GET /openvpn/status | jsonfilter -e '@.http_body.data.*.status'
This command assumes there is only one OpenVPN client configured on the device. If you have more, then you could replace the star symbol by the name of the VPN tunnel. The output of the command will return either 0 (disconnected) or 1 (connected):
root@RUTX09:~# /sbin/api GET /openvpn/status | jsonfilter -e '@.http_body.data.*.status'
0
1
As for GPIO, I currently do not have any information that the UBUS call will be removed, but if you’ll be moving to the new API, then the command to use to check the status of the digital input would be:
/sbin/api GET /io/status | jsonfilter -e '@.http_body.data[@.id="din1"].value'
Other pins will have different IDs.
API in combination with jsonfilter utility can be very powerful tools, and my provided examples can be optimized to suit your needs.
It should be noted, that using API (unlike ubus), the settings of the device can be changed as well. All calls can be found in the webpage provided in my first comment.
EDIT: It seems like there is an API call to get a specific GPIO pin status instead of using jsonfilter:
