I thought it was the last version, at least that’s what the system says, when will the Device network map function work? I’m sorry it doesn’t work when it worked in the previous version
Device network map not supported for RUTX_R_00.07.09.4 firmware version.
Please update your device firmware to the latest firmware version.
Are you referring to the RMS Network Map feature (Device details → Network)? If so, I’ve checked it in RMS and can confirm that it’s functioning properly.
Alternatively, if you’d like to check it via the router’s WebUI, you can find it under Status → Network → Topology.
Let me know if you have any further questions!
Hi, I restarted the router and the network maps are really working. Maybe it was an update, but it really told me to update. now everything works without problems. Thank you
