Noticing a new console error when accessing a test device that I updated to RUTX_R_00.07.08 a few days ago:
Just for completeness, I also tested this in a separate clean browser (Safari) which I don’t use and which has no plugins, history, or cache. Same error:
I have tried several devices to recreate the issue you are experiencing but was not successful. Since you mentioned it was a test device, there might be some configuration interfering. Could you try factory resetting it? Additionally, you can try deleting and reinstalling the Tailscale package to test this potential point of failure.
(note about Tailscale issue moved because turns out it’s unrelated)
I don’t know if factory resetting is going to gain much. I found the source (gzipped) for the index page at /www/index.html.gz, un-gzipp’ed it and inspected the code.
I see the following
Running that thru https://www.srihash.org/ it appears valid
So, I’m not sure what the “problem” is here, but it may just be cosmetic? I am a bit surprised you aren’t able to replicate it, as this doesn’t appear to be anything config-related.
Could it be that the CSP headers being sent by the RUTX make reference to a sha256 hash, but the source specifies a sha384 hash?
Also, when I tested the js resource (again, using https://www.srihash.org) its sha256 hash does not match what is passed in the headers…
This topic is about to auto-close ![]()
In any case, I updated to 7.08.1 and the issue is still present.
I also checked a few routers with older firmware, and can confirm that the bug was introduced somewhere between 7.04.5 → 7.06.10 (on the 7.04.5 systems, this error is not present, but it is present on all 7.6.10+ systems that I checked)
