RUTX_R_00.07.07.2 in RUTX50
After updating two RUTX50 in the above firmaware version, I can see the N78 band does not show 100Mhz but 80Mhz. The RUTX50 are located in different areas and they constantly showed 100Mhz before the update.
The frequencies you’re referring to relate to mobile band bandwidth. This bandwidth is set by mobile carriers, not by us or our routers. It can change due to network upgrades, optimizations, or regulatory requirements. For more information, I recommend contacting your ISP.
This answer is not accepted. I have two RUTX50. When I noticed the issue at my first one, then went to the second one and show 100MHz. Then I proceeded with the firmware upgrade to the second one and noticed the same 80Mhz. I am wondering if there is a UI bug.
Further to the above, I would like to report that after I downgraded to previous firmware, the N78 band shows again 100Mhz.
Thank you for bringing this to our attention. We will look into the issue.
You are welcome , keep up the good work you do.
Could you confirm if your internet speed changes when using 80MHz compared to 100MHz?
I don’t see any speed issue. Please note, that our Service Provider never offered 80Mhz bandwidth, so probably this is 99% a UI issue. But your developers should be in position to know better.
Any news about the issue?
Latest version 07.07.03 did not solve this problem.
