RUTX OS UI color bug prevents checking zone:lan pairs
I had an issue to validate correct settings while Zone creation:
Network → Firewall → Zones → add/edit dialog window → field “Allow forward from source zones” uses list of checkboxes “zone: lan”.
Unfortunately the text “lan” uses white font color and the background value “rgb(var(–clr-border-error-50))” does not exist therefore the background is also white.
White text on white background is not possible to read :wink: I guess the correct value should be “–clr-error-50”… Does anyone experienced the same issue?
(using latest RUTX_R_00.07.13.3)
Are you experiencing the same issue with the 7.13.14 firmware? If so, could you please provide screenshots of the zone you are referring to, highlighting where the color for the LAN zone is displayed incorrectly?
