Following up on our telephone conversation, please find the attached log files of the router. I would like to briefly describe the issue we are currently facing.When the router’s connection drops for any reason, the VPN tunnel is usually restored. However, in some instances, the connection restores but the VPN tunnel does not. When this occurs, we have to visit the site and manually restart the router to restore the VPN connection.Please review the logs and let us know if you require any further information or testing from our side.Thank you for your help.
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 16645.
