the latest firmware 7.19 on a RUTX 50 un-install the ZeroTier package.
Re-installing the package all of the settings comes back, the setup is not lost.
Best regards
Giovanni
Best regards
Giovanni
Greetings, triotech,
Thank you for your message,
Once the package is installed, you are able to access its configuration and set the settings in your case for ZeroTier VPN. I have tested it with a several versions of the firmware (7.17.5 , 7.18.3, 7.19) and I could not replicate the issue that you’re describing.
Therefore, for troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 16308.
Dear Vilnius,
could you re-send the form, I have not receive any form in my email inbox.
Thank you, kind regards
Giovanni
Hello Giovanni,
Thank you for your message.
I have resent the form to the email address associated with your community forum account. Please also check your spam or junk folder, just in case it was filtered there. Kindly let me know once you’ve received it.
So far I have only received an email with a link to a simple form that I have filled in and sent.
Nothing else
Kind regards
Giovanni
Additional email was sent asking you to provide additional information, please check you email inbox for further instructions.
I also noticed this however zerotier gets installed back after waiting for a short period with the correct settings etc
