RutOS (RUTX10) API access
We are using the API to get and modify information and parameters of the device from an application.
Since firmware 7.14, there is a change in the behaviour of the API (1.6) and we cannot use it anymore. API 1.5 was ok.
What are the main changes ?
Could it be possible to compare different API versions ?
Thanks for your help.
Good afternoon,
Thank you for your query.
We are currently working on it, and will be back with a response as soon as possible.
Thank you for your patience,
Teltonika Team
Good afternoon,
The main differerence in these API versions is that with firmware 7.14 and API 1.6, legacy POST/GET interfaces are removed for improved security; all device interaction must use the Web API.
More information on API functionality can be found here : https://developers.teltonika-networks.com/tutorials
Some information about product changes, including changes in API can be found in product notifications section of device. Example : RUTX10 Product Change Notifications - Teltonika Networks Wiki
Please clarify if that does not answer your question.
