RUTOS relay with new firmware (relayd)
Hi, im having trouble with the new firmawre to make the relayd configuration. I have a RUT955 who has internet access trough mobile and a wifi access point enabled.
I have a RUT360 with who i connect trough WIFI (client mode) to the RUT955. I install Relayd and there is allready put in:
Interface: wan
Wireless interface: wifi1
So the internet is working, i see also that the RUT955 gives an IP to RUT360, but then i also see that RUT360 is giving IP’s to the devices connected to the router.
In the configuration example “RUTOS” its written to turn off DHCP after enabling Relayd, but how with the new firmware there is no option (or maybe its written different)?
I also put the same SSID for both routers but when i look them up i see both of them, how can they be merged to only one instance?
And a third question, i join trough WIFI a device (clocking device), i see the IP of the device in the device and also in the RUT955 but cant access it trought the clocking software if i in the other hand connect it trough lan cable i can access it without problem. Any advice?
This topic was automatically closed after 18 days. New replies are no longer allowed.
