RutOS campsite query
Anyone out there who can help with RutOS app regarding campsite mode using an RUTX50. If I connect to a campsite WiFi using the RutOS app making it the active source, am I correct in assuming that this campsite WiFi connection uses their data rather than my own sim data? The reason I ask is it appears to be working ie internet data etc until I remove my SIM card then I’m unable to access internet which makes me believe I’m unknowingly using my valuable sim contract data when I thought I was using campsite data. I’ve also noticed that no led WiFi light is currently active on RUTX50 only the default device WiFi. Any help would be greatly appreciated otherwise I wasted a lot of money on the device that my laptop or phone can do without it seems any frustration or problems.
Does this post help …
… I don’t use the RutOS app but hopefully it may give some insight.
Thanks for the reply, I wanted to try something similar to your suggestion but came across a problem logging into webui, couldn’t enter a password for some reason, some comments suggested factory reset of RUTX50 which I did, cleared cache from laptop all to no avail. I do feel like giving up sometimes but will have to try and contact teltonika support directly
Just for info I’ve managed to login to webUI via my phone not ideal but nonetheless I’m in having followed the steps forwarded by Mike thanks, I came across this conflict “Network conflict detected. This interface shares the same IPv4 subnet with one or more other interfaces: “Ian”. This may cause loss of Internet connectivity via the WAN interface” Having resolved this issue by a click of a button I’m now using WiFi instead of mobile.! Thanks again for your help
