I’m using the freebox Pro for my VPN server (French provider).
This VPN is a IPsec/IKEv2 , I only have an address, a login and a password to connect my devices on it.
I want to connect the RUTM52 on the VPN, to have an IP address on the VPN and after that connect to it as server.
Is it possible?
Or is it better to use an external VPN provider like NordVPN or Express VPN?
Thank for answer
Marc
Yes, it should be possible to establish an IPsec tunnel between your RUTM52 and your Freebox Pro (VPN server), provided that the Freebox has a public IP address.
For more details and a configuration example, you can refer to the IPsec configuration wiki article, which might bring better insights, available here:
If you encounter any difficulties while setting up the tunnel, feel free to reach out here.
Also, if the tunnel connection doesn’t come up, please provide the IPsec logs, preferably from both the RUTM52 and Freebox.
