Hi
I’m looking at the RUTM52 and I’m wondering what modem is inside and how many N bands can it aggregate (on a 5G SA/NSA network)?
Thanks!
Hi
Thanks!
Hi, @tirkiz
Supported MIMO:
Uplink: 2 × 2 MIMO*2
RG501Q-EU:
NSA: 3.3 Gbps (DL)/650/600 Mbps (UL)
SA: 2.1 Gbps (DL)/900 Mbps (UL)
So, the RUTM52 has the same modem as the RUTX50 (which I have had for two years)
Thanks ![]()
It’s not RG501Q. RUTM52 has newer, release 16 module inside.
" I recently received an engineering sample from Teltonika, the RUTM52, which is not yet available for purchase online. This new device features two 5G modems (RG501Q-EU). It has a MediaTek MT7621A CPU, Dual-Core, 880 MHz, MIPS1004Kc (which seems quite slow), 256 MB of DDR3 RAM, and storage consisting of a 16 MB serial NOR flash and a 256 MB serial NAND flash.
I am currently attempting to generate an OMR image for it, but I have been unsuccessful with both kernel versions 6.6 and 6.1. "
So… A customer was describe what he have in hands or ???
It is just a prototype?
Teltonika update the hardware of the device?
RUTM52 - Quectel RG520N-EB
LTE Category - DL Cat 19/ UL Cat 18
5G SA Sub-6 - 2.4 Gbps (DL)/ 900 Mbps (UL)
5G NSA Sub-6 - 3.4 Gbps (DL)/ 550 Mbps (UL)
Teltonika RUTM52 Datasheet
2 x 5G Sub-6 GHz SA/NSA 2.1/3.3Gbps DL (4x4 MIMO) 900/600Mbps UL (2x2
MIMO);
WAN - 1 x WAN port 10/100/1000 Mbps
LAN - 4 x LAN ports, 10/100/1000 Mbps
What?? no LAN with 2.5Gbps? ha ha ha
CPU - MediaTek, Dual-Core, 880 MHz, MIPS1004Kc! For a dual 5G LTE?! ha ha ha
About MediaTek, Dual-Core, 880 MHz, MIPS1004Kc
5-port 10/100/1000 SW/PHY and one RGMII*
