RUTM50 Not Connecting to Custom APN (staticipwest.telus.com)
I purchased a RUTM50 to use as a backup internet over 5G. I signed up for a static IP address with our mobile provider, Telus (Canada).
I was instructed to set APN “staticipwest.telus.com” to receive a Public Static IP. When I tested the SIM card with a iPad, it received the IP address Telus provided. However, when I inserted the SIM into RUTM50, network status stays “disconnected”. 5G LED is blinking and no LED on SIM1.
When I set Operator selection mode to “Manual” and scan operators then select Telus, it briefly connected to Telus and received the IP then immediately disconnected again. Since then I can’t get it connected at all.
It connects only when I set the APN to Auto but then it receives a private IP address.
I downloaded the troubleshoot file after the router had the IP briefly.
Please advise.
Thanks.
DB
First, could you please clarify what product code your RUTM50 has? This can be found under the WebUI → Status → System - there’s a product code for North America & for EMEA (Europe) - if yours is an EMEA product code, it would make sense as to why it’s not connecting:
You can find these codes under the Ordering section: https://www.teltonika-networks.com/products/routers/rutm50
Interestingly enough, Telus’s website claims that the APN should be set to sp.telus.com - could you try that one as well?
RUTM5000XXXX
It finally got connected last Saturday but then got disconnected again 10 hours later. It won’t connect again this morning through APN staticipwest.telus.com. It still connects through sp.telus.com without a problem.
Telus instructed me to use staticipwest APN for a static IP address.
I purchased this unit through “novotech” specifically because it’s certified for North America.
sp.telus.com and staticipwest.telus.com should be the same according to their website, does using sp.telus.com provide you with a different IP address than expected? If not, just use the sp.telus.com APN.
No. “sp.telus.com” won’t get me a public IP address. it connects fine but it assigns a private IP address.
After fiddling with it a bit, I figured the problems were coming from the unstable 5G connection. Once I set it to 4G Only, it connected immediately and received the static IP.
Now I changed back to 5G/4G Auto with manual 5G mode and bandwidth, according to the screenshot I took when it was connected to 5G once. It’s currently connected with the IP. Fingers crossed.
Thanks for clarifying. If you encounter further 5G instabilities, do let me know, as I may be able to do try & do a modem firmware upgrade on your device to see if that improves the situation.
it’s been up last 24 hours since i changed it to manual mode. even it connects immediately when i restart connection to test. i’m running firmware RUTM_R_00.07.20.3.
