RUTM50 – Flat wall mounting options
I’m looking for a suitable mounting solution for the Teltonika RUTM50.
I need to mount the router flat against a wall, with its large rear surface parallel to the wall, not on its narrow side.
The rear of the RUTM50 only has ventilation slots and no mounting points. The narrow sides have mounting grooves, but the PR5MEC12 mounting kit does not appear to support the required orientation.
Is there an official Teltonika mounting accessory or another recommended solution for this type of installation?
I’d prefer a secure, screw-mounted solution without modifying the router or obstructing its ventilation.
Thanks in advance for your help!
Thank you for reaching out.
You can use the Surface Mounting Kit (PR5MEC12) to mount the RUTM50 with its large rear surface parallel to the wall. The router has mounting grooves on both short sides and on the back. For the orientation you described, attach the brackets to the rear groove, then secure them to the wall with screws.
This video demonstrates how to fit the surface mounting kit starting at 1:37. Watch the installation guide.
T.
Hi T.,
Thank you for your reply.
However, there are no dedicated mounting grooves on the back of my RUTM50, only cooling grooves.
Can these cooling grooves also be used to attach the PR5MEC12 mounting brackets?
Thank you for clarifying!
A.
Among the cooling grooves on the back of your RUTM50, the groove closest to the middle is the dedicated mounting groove. This groove can be used to attach the PR5MEC12 mounting kit.
T.
