I have a new RUTM30 unit I will install in a location that (currently) only has an external 2x2 MIMO antenna. Which 2 of the 4 mobile antenna connectors should I connect the external antennas to? The connectors are all marked the same on the unit chassis.
I found several answers in the forum for RUTX50 but none for this model, which has a different modem inside.
Hello, I own a RUT955 and want to upgrade to the RUTM30. I have the following antenna connected to the RUT955: 003R-00253 Can I use this antenna with the RUTM30? Which antenna connectors on the RUTM30 would be best to connect to the roof mounted antenna? For the remaining two antenna connectors, I will use the included flat antennas. Wondering which combination of “indoor small antennas” + roof mounted antenna will be best, across ANT0, ANT2, ANT3 and ANT5.
I’d advice - from experience - against not having identical antennas for all connectors. The setup I tried caused modem resets during heavier network traffic. The issue was fixed by replacing the two included antennas with identical outdoor yagis (4x4 MIMO with 4 Iskra P-60).
