Dear Teltonika Support Team,
We are facing a mobile connectivity issue with a Teltonika RUTM20 and would appreciate your technical support in identifying the root cause.
Device / SIM Details
Device: Teltonika RUTM20
Original SIM: Ooredoo Kuwait Public IP SIM
APN: b2b.wataniya.com
Authentication: None
SIM Slot: SIM 2
Issue Observed
The Ooredoo SIM works normally in a mobile phone with good 5G Internet performance. However, when inserted into the RUTM20, the connection is unstable.
At different times, the router shows:
Operator: Ooredoo / sometimes N/A
Operator state: Searching / Denied
Network type: 5G (NSA)
Data connection: Sometimes Connected, but then disconnects
IP address: Sometimes unavailable
APN: Sometimes displayed as N/A in the status page
The router is detecting the Ooredoo network and LTE/5G cells, but it cannot maintain a stable data connection.
Troubleshooting Already Performed
We have performed the following steps:
Hard reset the RUTM20 to factory defaults.
Reconfigured the Ooredoo SIM manually.
Disabled Auto APN.
Configured APN as:b2b.wataniya.com
Set Authentication Type: None.
Set Mode: NAT.
Set Protocol: Mobile.
Checked the SIM status – SIM is detected correctly.
Confirmed the SIM works normally in a mobile phone with 5G Internet.
Checked the mobile status and cellular parameters.
Checked and reconnected the cellular antennas.
Tested the router outside/with better positioning.
We also inserted a different personal SIM with an active Internet/data plan into the RUTM20. The same connectivity issue occurs, which indicates that the issue may not be related specifically to the Ooredoo Public IP SIM/APN.
Additional Important Test – RUT951
We also have another Teltonika router, RUT951.
We inserted the same Ooredoo Public IP activated SIM card with the same APN/service into the RUT951.
The RUT951 works normally and maintains a stable Internet connection using the same SIM.
We would appreciate your guidance on the recommended troubleshooting procedure and the next steps to identify the root cause.
Mohamed Thalif
Aspire General Trading Co.
+965 69097670
