RUTM11 wifi connection
Im able to establish connection to my RUTM11. But when im connected to it on the LAN , if i activate the wifi ,when the RUTM11 connects to it i am no longer able to detect the RUT neither can i ping it.
Is it some firewall issue or what could it be ?
If I understand correctly, you are able to access the RUTM11 when your PC is connected via Ethernet (e.g., using the IP address 192.168.1.1), but you are unable to reach the router’s IP when connecting from your PC(or phone) via Wi-Fi — is that correct?
If so, please ensure that in System → Administration → Access Control in WebUI, the options to allow remote HTTP(S) access (for WebUI) and SSH access are enabled.
If I misunderstood the issue, could you please provide a more detailed explanation?
