Ruth 241 esim Pin code
I recently bought an RUT241 eSIM. I have activated the eSIM card and everything works fine. However, when I restart the router, the eSIM is not activated until I re-enter the SIM PIN via Status → Network → Mobile. After that, it works again. This happens even though I have already entered the PIN in the SIM2 configuration.
Is there a solution so that I don’t have to enter the PIN every time? I am using the router in my caravan.
Thanks for your reply.
Interesting, after entering PIN in configuration it shouldn’t ask again.
Alternative you can go to Network→Mobile→Utilities and disable PIN lock.
Wiki: RUT241 Mobile - Teltonika Networks Wiki
Thanx it works close you can close the ticket
