Rutc50 VPN Wireguard not working as expected
Hi Matas, have created the backup, that was easy. Hope I never need it ….
Regarding the changes :
  • on the FritzBox side I chosed VPN Network connection and not single device VPN
  • The ip range for the tunnel is 10.10.10.0, so completely different from Rutc50 or FritzBox
  • I have a static route now for Inwi, which is my current LTE provider
  • I have not touched any zones etc
  • On the FritzBox side the setting „route everything through the VPN“ had to be turn off !!
My biggest worry is the static route … is this really nessecary and what happens when being back to Europe in few days with a new LTE provider.
as it is hard to get a documentation for only the relevant VPN details I can‘t really list all the details which are different to what we did last year in the session.
my recommendation would be to:
Let me see if the current setup survives until I am back home end of march.
If this is then still of interest for you, we can have an AnyDesk session again for you / someone else to check the details and document them. I can share all Fritz:Box and Rutc50 settings then. You are more the experts than I am and could possibly see the relevant pin-points faster then I would be able to tell.
That sounds good, will be waiting for further updates. Thank you for sharing!
