RUTC50 VPN connection to Mikrotik Router Dynamic IP
I’m trying to setup a VPN connection with my RUTC50 as client to my Mikrotik Router at home. I’m using L2TP over IPsec. My Mikrotik Router has a dynamic IP and has it’s build in DynDNS service so I can connect to it using the Routers hostname from anywhere with my iPhone, Macbook or any other device without a problem.
The RUTC50 has a problem and giving me the following Log entry:
Fri Oct 11 11:45:17 2024 daemon.info ipsec: 13[IKE] <MCI-MCI_c|4> IDir ‘My-Router-IP’ does not match to ‘My-Router-Domain
The RUTC50 is complaining that my Mikrotik Router is responding with it’s current IP and not with it’s domain. If I use the current IP to connect it works without any problem.
Well this is an issue on the RUTC50 because all other clients are able to connect, I guess most of the user don’t have and don’t need a fixed IP at home and have the same issue.
Hope someone can help.
Could you please share your VPN configuration from the RUTC50?
Thank you for your Reply. Yes of course I can share the config of the VPN in RUTC50, as I mentioned I’m using L2TP over IPsec to connect to my home as all my other devices do.
I hope some screenshots will do it, first the IPsec config:
And now the L2TP settings:
in the Server field I want to put the DYN-DNS Hostname of my router, currently I have there the IP from my router but the IP has changed already so the connection is not working right now. If I put the current IP of my router in both server fields for IPsec and L2TP the VPN works.
Thank you for all the information.
I kindly ask you to send me a troubleshoot file. I have sent you a form to fill out, and once completed, I will contact you privately regarding this. For the ticket ID, please use “9756”.
