Hi Team,
i just had a quick call with one of your engineers.
We have a RUTC50 with eSIM functionality and it worked till monday pretty well. After i saw that the VPN Tunnel went down (certificate and route based), i was able to connect via the RMS portal and saw that the tunnel was still “connected”. But i wasn’t able to reach the router via the tunnel nor the devices (switch) behind the router. So i took a look at the firewall rules and all custom rules were in starting state. Then i tried to restart the firewall on the cli. Nothing happened. After that i rebooted the router and was not able to connect locally via LAN/WLAN anymore (no DHCP). The i resetet the device via the reset button. I was able to logon with the default settings again. Then i tried to restore a backup, which i made a few hours before.
In the verify area i got a lot of messages.
Restore from backup
Browse
or drag and drop your file here
Only configuration file from identical device with same or lower firmware version can be uploaded.
Teltonika Networks
Wiki
Community Forum
Licenses
Backup file validation failed
Validation failed
Please review all backup validation errors listed below and either upload corrected backup file or force apply with the current file despite the errors. Kindly note that some conflicting areas may not be migrated.
Show checksums
From device:
RTR01-xxxx
File:
backup-xxx-2026-04-27.tar.gz
From firmware:
RUTC_R_00.07.22.1
Validation errors
Documentation
Visible columns (5 of 5)
Message
Profile
Endpoint
Option
Value
Must be one of the following values [wan, mob1s1a1, mob1s2a1].
Default
/failover/members/config
interface
mob1s3a1
Default
interface
mob1s3a1e1
Default
interface
mob1s3a1e1
Default
interface
mob1s3a1e3
Default
interface
mob1s3a1e3
Default
interface
mob1s3a1
Data limit configuration name must match a network interface configuration id.
Default
/data_limit/config
URL
Default
/data_limit/config
URL
Must be one of the following values [*, lan, wan, eSIM, newzone].
Default
/firewall/traffic_rules/config
src
OMICRON
Must be one of the following values [, lan, wan, eSIM, newzone].
Default
dest
OMICRON
Default
src
OMICRON
Default
src
OMICRON
Default
dest
OMICRON
Must be one of the following values [ORG_RST_LAN, wan, mob1s1a1, mob1s2a1, mob1s3a1e1, ORG_RST_TRAINING, ORG_RST_Guest].
Default
/ip_routes/ipv4/config
interface
OMICRON
Default
interface
OMICRON
Provided member ‘wan_member_mwan’ does not exist
Default
/failover/policies/config
Validation
Provided member ‘mob1s1a1_member_mwan’ does not exist
Default
Validation
Provided member ‘mob1s2a1_member_mwan’ does not exist
Default
Validation
Provided member ‘mob1s3a1_member_mwan’ does not exist
Default
Validation
Provided member ‘mob1s3a1e1_member_mwan’ does not exist
Default
Validation
Provided member ‘mob1s3a1e3_member_mwan’ does not exist
Default
Validation
Must be one of the following values .
Default
use_member
wan_member_mwan
Default
use_member
Default
use_member
Default
use_member
Default
use_member
Default
use_member
Provided member ‘wan_member_balance’ does not exist
Default
Validation
Provided member ‘mob1s1a1_member_balance’ does not exist
Default
Validation
Provided member ‘mob1s2a1_member_balance’ does not exist
Default
Validation
Provided member ‘mob1s3a1_member_balance’ does not exist
Default
Validation
Provided member ‘mob1s3a1e1_member_balance’ does not exist
Default
Validation
Provided member ‘mob1s3a1e3_member_balance’ does not exist
Default
Validation
Default
use_member
wan_member_balance
Default
use_member
Default
use_member
Default
use_member
Default
use_member
Default
use_member
Failover interface configuration ID must match an ID of a network interface configuration.
Default
/failover/interfaces/config
URL
Default
URL
DHCP configuration ID must match an ID of a network interface configuration.
Default
/dhcp/servers/ipv6/config
URL
Default
/dhcp/servers/ipv4/config
URL
Network interface IP address and netmask must be set.
Default
start_ip
10.203.9.10
End IP address can not be greater than the last network address. (10.203.9.127)
Default
end_ip
10.203.9.250
Must be one of the following values [10mh, 10mf, 100mh, 100mf, 1000mf].
Default
/ports_settings/config
advert
10baseT1S-H
Default
advert
10baseT1S-F
Default
advert
10baseT1L-F
Default
advert
100baseFX-H
Default
advert
100baseFX-F
Default
advert
100baseT1-F
Default
advert
1000baseT-H
Default
advert
1000baseKX-F
Default
advert
1000baseT1-F
Default
advert
1000baseX-F
Value must be an integer and range of the value must be from 1 to 1.
Default
/interfaces/config
esim_profile
2
Name already used for a configuration
Default
/interfaces/config
Validation
Default
/interfaces/config
esim_profile
3
Invalid VLAN ID given! Only unique IDs are allowed
Default
/devices/port_based_vlan/config
Validation
Port (lan1) is untagged in multiple VLANs
Default
Validation
Port (lan2) is untagged in multiple VLANs
Default
Validation
Port (lan3) is untagged in multiple VLANs
Default
Validation
?:0: attempt to index field ‘?’ (a nil value)
Default
Lua
Must be one of the following values [wan, eSIM, newzone].
Default
/firewall/zones/config
in
OMICRON
Default
out
OMICRON
Must be one of the following values [lan, eSIM, newzone].
Default
in
GUEST
A string of a-Z, 0-9 and _ characters is accepted.
Default
network
Must be one of the following values [/etc/certificates/uhttpd.key].
Default
/ipsec/config
key
/etc/certificates/cert_cert-rtr01-rst.key
‘German Language Support (Deutsch)’ configurations may not migrate properly until the packages are installed. Install them now or proceed and install them later.
I stopped the backup process and downgraded the firmware to an older version and tried to import the older backup (from the older firmware) and that worked.
But there was no bootstrap eSIM profile anymore. And was not able to import the “old” working eSIM profile anymore.
Made an upgrade again, no eSIM, reset of the router, no eSim…
Inserted a physical SIM, thats working. Configured everything like it was before. VPN is working again, but if i reboot the device, the static routes through the tunnel don’t work anymore.
In the RMS portal if i try to upload an eSIM profile, it says that there is no eSIM modem on the Router…
Version: RUTC_R_00.07.22.1
Any thoughts on that problem?
BR,
Christian
