Is there a way to limit the number of authentication requests when the device is used in the sta
mode?
For example, it’s setup to connect to three WiFi networks (multi_wifi) with different priority each. Everything works as expected, the device connects to a WiFi network based on the priority set. However, if the password
from the 1st WiFi changes, it keeps trying to connect to it no matter what.
daemon.notice wpa_supplicant[1946]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="xxxxx" auth_failures=24 duration=120 reason=WRONG_KEY
Is there a way to limit the number of tries and to move to the next available WiFi network?
Thank you
