[RUT976] Dual stack IPv4/v6 ip address assignment when using multiple APN sessions
During testing I noticed that one of the WAN interfaces does not request IPv6 address in dual stack mode when two such WAN interfaces are enabled. PDP type is configured to IPv4/IPv6, but from the network logs, in Create Session Request, requested PDN type by RUT976 is “IPv4” only.
Is this known issue? If needed, how can I send the logs for analysis?
Jakub Czekaj
Thank you for reaching out. To assist and investigate the described issue effectively, we’ll need to continue this process privately. You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 13614 when submitting it. Once the form is completed, we’ll contact you directly via email to troubleshoot the issue in detail and help work towards a solution.
